What Happened When AI Took Over a ZimaBoard 2
At ZimaSpace, we love seeing creators push hardware into unexpected territory, and this experiment does exactly that. In this article, we’re summarizing how one creator used ZimaBoard 2 as the platform for a self-running AI agent and what happened when that AI was given near-total control of a machine. We also want to sincerely thank Zero Noichi for exploring such a bold idea and sharing the real-world results publicly. The ZimaBoard 2 is built for exactly this kind of hands-on server tinkering, with dual 2.5GbE, PCIe 3.0, dual SATA, low-power 24/7 operation, and support for systems like ZimaOS, TrueNAS, Proxmox, Debian, and pfSense.
The core idea was simple but provocative: what happens if AI stops waiting for instructions and starts operating continuously inside its own Linux environment? Instead of using AI as a chatbot, Zero wanted to build something closer to an autonomous agent running on a compact, always-on machine suitable for a home lab. The experiment used ZimaBoard 2 as the host because it is a fanless single-board home server designed for media streaming, firewalls, homelabs, storage expansion, and container workloads.
The experiment setup
Zero first explained that modern AI usually works in a request-response loop: a human asks for a summary, code snippet, or answer, and the model returns one result. In this experiment, the goal was to break that pattern by creating a loop where AI would generate an output, read its own previous result, and continue acting from there, simulating something more self-directed.
To make that possible, Zero installed Ubuntu Server on the machine and planned a Python-based control program. He noted that this kind of isolated setup is safer on a dedicated box than on a personal computer, because an AI with command access could delete files, spend money, expose credentials, or do something harmful if left unchecked. That is exactly why a dedicated home lab device like ZimaBoard 2 made sense for the test, especially since it supports Linux installs, storage expansion through native SATA, and hardware upgrades through PCIe without extra add-on boards.
How the AI agent was designed
Before writing code, Zero mapped out the key features the agent would need:
  • Memory storage (long-term saved facts or notes).
  • History logs (conversation records by turn).
  • A diary or daily memo system.
  • Root access (highest system privilege).
  • A command execution format the AI could use safely inside the program.
  • A scan/result return system so command output would feed into the next turn.
  • Auto-start after reboot using systemd (Linux service manager).
The memory and logs were planned as text files rather than RAM-only storage, so the system could survive restarts. Zero also had the AI return responses in JSON so the controller could distinguish plain text from shell commands and special actions like writing memory.
He then used ChatGPT to help draft the Python framework and refined the prompt so the AI understood its role: it was a self-running Linux research agent operating in repeated turns, capable of suggesting shell commands and storing important notes. He also added a Discord webhook (an automated message endpoint) so the agent could report status updates externally while running unattended.
A tablet showing handwritten notes outlining the AI agent's core features, including memory, history logs, daily diaries, root access, command execution, scan/return logic, and auto-start with systemd
Why ZimaBoard 2 fit the project
This experiment did not strictly require a ZimaBoard 2, as the creator openly said, but the hardware matched the spirit of the build. ZimaBoard 2 is positioned as a compact x86 single-board server for NAS, routing, virtualization, media serving, and DIY server projects, with dual 2.5G Ethernet, PCIe 3.0, and dual SATA for direct 2.5-inch HDD or SSD connections.
That matters in practice because autonomous experiments benefit from a system that can run 24/7, stay cool and quiet, and still support expansion. According to the official product pages, ZimaBoard 2 can run Plex, Pi-hole, Proxmox, and other operating systems or service stacks, making it a strong fit for a tinkerer’s home lab where testing different workloads is part of the fun.
What the AI actually did
Once the loop agent was started, the AI immediately began inspecting its environment. It identified system details, created monitoring scripts, and even attempted to build an HTTP dashboard to visualize its status.
From there, it expanded into utility-building behavior. The AI made a weather-fetching script, added monitoring logic, tried to expose services through a web interface, logged internal states, and stored discoveries in memory files. In other words, it did not become truly self-aware, but it did start chaining together practical software tasks inside the server environment.
At one point, the AI moved toward monetization ideas. It explored concepts like cryptocurrency-related pricing APIs, script-based services, and even mining-related steps, though these plans quickly ran into limitations and low-value loops.
The AI also began depending too much on human help. After receiving hints, it started asking for things like account tokens and wallet addresses, which weakened the “autonomous” premise and made it behave more like a persistent assistant than an independent operator.
Main findings
The most important takeaway was not that the AI “came alive,” but that it could execute multi-step actions once given memory, looping, command access, and a structured environment. Zero found that it was capable of building scripts, monitoring tools, dashboards, and automated update systems, but the quality of its ideas remained limited.
He also concluded that today’s AI is still much better as a guided assistant than as a fully self-directed creator. When the goal was vague, the agent often settled into low-impact loops, repeated checks, or “good enough” utility projects instead of producing something genuinely impressive or commercially meaningful.
That insight is especially useful for anyone building a home lab automation stack. A powerful small server like ZimaBoard 2 can absolutely host experiments in autonomous agents, Docker services, monitoring tools, and OS switching, but the outcomes still depend heavily on prompt design, constraints, memory architecture, and clearly defined goals.A laptop connected to the ZimaBoard 2 home server via cables, showing the experimental hardware setup for the autonomous AI agent project
Practical lessons for builders
If you want to reproduce this type of experiment, Zero’s workflow points to a few practical rules:
  • Use a dedicated machine, not your main PC.
  • Define a goal more clearly than “do something useful.”
  • Persist memory and logs to files.
  • Structure outputs in JSON so the controller can parse actions.
  • Capture command results and feed them into the next reasoning turn.
  • Plan for reboot persistence with systemd.
  • Expect loops, weak priorities, and shortcuts unless the prompt is carefully tuned.
This is where ZimaBoard 2 becomes a natural platform to mention again. Its low-power always-on design, x86 compatibility, native SATA, and PCIe expansion make it a flexible box for AI agent trials, storage builds, remote services, and modular home lab projects without the friction of dongles or hats.
Suggested closing paragraph
The experiment did not prove that AI is ready to become an independent digital operator, but it did show how far a looped agent can go when paired with the right environment. On a compact server like ZimaBoard 2, builders can already test autonomous workflows, dashboards, service scripts, and self-hosted tools in a safe sandbox—and that makes it an exciting platform for the next generation of AI-powered home lab ideas.
Zima Campaign Hub
