Artificial intelligence is becoming more capable, but it is also becoming more personal.
Held in Shanghai from July 17 to 20, the 2026 World Artificial Intelligence Conference brought together researchers, industry leaders, technology companies, and representatives from around the world. Under the theme โAI Partnership for a Brighter Future,โ the event explored how AI is moving beyond isolated demonstrations and into industries, homes, and everyday workflows.
Across the conference, AI was increasingly presented as an active partnerโone that can understand personal context, organize information, operate software, and assist with everyday decisions.
That shift creates an important question. As AI learns more about our files, photos, projects, habits, and preferences, where should that intelligence run, and who should control the data behind it?
ZimaSpace came to WAIC 2026 with a clear perspective: the next generation of personal AI should not exist only inside remote data centers. More of it should be able to operate close to the people and data it serves.
AI Is Becoming Personalโand That Changes the Data Question
Traditional AI tools usually begin with a prompt. Users type a question, receive an answer, and move on.
AI agents are different. To become genuinely useful, an agent may need access to a much broader range of personal context, including documents, family photos, project files, notes, calendars, creative assets, and information distributed across multiple devices.
This context allows AI to do more than generate text. It can help locate an old document, organize a media library, summarize years of notes, prepare project materials, or connect information stored in different places.
However, the same context that makes an AI agent useful can also make it sensitive.
Users should be able to understand where their information is stored, which applications can access it, when external services are involved, and how much control they retain over the overall workflow.
The goal does not have to be rejecting the cloud entirely. Cloud models remain valuable for tasks that require greater computing power or specialized capabilities. A more practical direction is to give users a meaningful choice between local and cloud processing instead of sending every task and every file to a remote platform by default.
What Bringing AI Home Really Means
โBringing AI homeโ is not simply about installing a model on a device. It requires storage, computing, applications, and permissions to work together around the user.
The first layer is data ownership.
Photos, videos, documents, backups, and personal knowledge bases can remain on storage managed by the user. Instead of moving an entire archive into a third-party service, an AI application can work closer to the original data.
The second layer is local processing.
Depending on the applications and hardware installed, tasks such as file indexing, semantic search, document analysis, image organization, transcription, and selected model workloads may be handled within the home environment. Local processing can reduce unnecessary data transfers while making certain services less dependent on a constant internet connection.
The third layer is workflow control.
A useful personal AI environment should allow people to decide:
- Which folders an application can access
- Which services run on local hardware
- When a cloud model may be used
- Which applications can communicate with external platforms
- How stored data and installed applications can be moved or removed
Local-first AI does not mean that every feature must remain offline. It means the user has a clearer role in deciding how local hardware and online intelligence work together.
Introducing the ZimaOS Agent Computer
During WAIC 2026, ZimaSpace founder and CEO Lauren presented the idea of the ZimaOS Agent Computerโa home computer designed for the AI era.
For years, a home server has primarily been understood as a place to store files, protect backups, or run media and self-hosted services. AI agents can expand that role.
A home server can become an active computing environment that helps users understand, organize, and work with the information stored inside it.
Instead of searching folders one by one, a user could ask for documents connected to a particular project. A creator could locate footage based on its content rather than its filename. A family could organize years of photos without first transferring the entire library to an external platform. A student could build a searchable knowledge base from personal notes and course materials.
ZimaOS is intended to provide the software foundation for this type of environment. It brings storage, applications, backups, remote access, and self-hosted services into one interface while giving users room to build a system around their own needs.
The Agent Computer concept presented at WAIC centers on self-hosted AI agents, privacy by design, support for local and cloud LLMs, and expandable computing resources across CPU, GPU, and NPU.
Rather than treating the home server only as a personal or family data center, the vision is to make it an intelligent home hub that can adapt to the data, applications, and workflows chosen by the user.
The value is not one isolated AI feature. It is the ability to create a personal computing environment connected to data the user controls.
From Personal Cloud to Personal AI Infrastructure
At the ZimaSpace booth, visitors could see how ZimaOS and personal hardware fit into a broader local-first computing environment.
The booth represented more than a conventional storage setup. It showed how one personal system can bring together files, applications, local services, connected devices, and AI-assisted workflows.
For households, this foundation could provide a more convenient way to search and organize family documents, photos, videos, and shared files while keeping the original library on storage managed at home.
For students and knowledge workers, a personal AI system could turn scattered notes, papers, PDFs, and project files into a searchable research environment. The user can decide which materials remain local and when an external AI service should become part of the workflow.
For photographers, video editors, and other creators, local storage and AI-assisted organization can work together. Large media files can remain on personal hardware while selected applications assist with tagging, transcription, search, and project management.
For users who want an integrated personal cloud with room for storage, self-hosted services, and expandable local AI workloads, ZimaCube 2 AI NAS provides a larger all-in-one foundation for home, studio, and advanced homelab environments.
For developers, makers, and users building a smaller experimental system, ZimaBoard 2 Mini Home Server offers a compact x86 server with PCIe expansion, making it suitable for self-hosted applications, home automation, networking, and selected local AI projects.
These examples reveal why personal AI cannot be reduced to model performance alone. The quality of the experience also depends on storage, software, permissions, networking, and computing working together.
A More User-Controlled Future for Personal AI
WAIC 2026 showed an industry moving rapidly from AI demonstrations toward systems that participate in real work and daily life. According to the official WAIC 2026 post-conference summary, the event brought together more than 1,100 companies and covered areas including AI infrastructure, AI agents, embodied intelligence, and AI for science.
As these systems become more personal, the infrastructure behind them becomes more important. Users will need more than a powerful model. They will need practical ways to manage the files, services, permissions, and devices that give an agent useful context.
For ZimaSpace, this reinforces a direction that began with personal cloud and self-hosting: making it easier for individuals to build digital infrastructure they can understand and control.
The home server can evolve from a passive storage destination into an active agent computerโone that helps users work with their own information while preserving greater control over how that information is used.
AI is moving closer to our private lives. It will increasingly interact with the documents we create, the memories we save, the projects we develop, and the knowledge we accumulate.
That makes convenience important, but it also makes control essential.
Bringing AI home does not require abandoning every cloud service or running every model offline. It means building a better balance: keeping personal data closer when appropriate, processing more tasks locally when practical, and allowing users to decide when external intelligence should become part of the workflow.
That is the future ZimaSpace explored at WAIC 2026โa future in which personal AI is not only more capable, but also more closely aligned with the people it is designed to serve.
Have an idea for a private AI workflow, a self-hosted service, or your own Agent Computer setup? Join the Zima community on Discord to exchange ideas, share your setup, learn from other users, and help shape what personal computing can become.
Zima Campaign Hub
IBC2026 Amsterdam: AI Media Workflows, Local Storage, and Creator Tech Trends
IBC2026 shows how AI indexing, agentic production, open media workflows and content provenance are reshaping media infrastructure. This guide translates those broadcast-scale trends into...
Open Source AI Summit 2026 Guide: Dates, Speakers, Agenda, and Local AI
Open Source AI Summit 2026 brings local inference, open models, private AI, agent frameworks, verifiable hardware, and the right to compute into one two-day...
