Home Assistant may reprocess existing data after an upgrade because new code must reconcile stored schemas, indexes, caches, statistics, and integration state with changed expectations.
The original sensor readings are not necessarily being collected again. Instead, the upgraded system may transform tables, rebuild derived structures, reload configuration entries, or recalculate summaries so old state remains usable under the new version. The duration depends on data volume, storage latency, available temporary space, integration count, the database engine, and the exact release path.
An Upgrade Changes How Existing State Is Interpreted
Home Assistant persists more than configuration text. Recorder tables, entity registries, device metadata, integration entries, statistics, and caches all encode assumptions made by the version that wrote them. When new code changes those assumptions, it must either translate existing state or regenerate a compatible representation before normal use.
This is the general purpose of a controlled software migration: move data and behavior from an old representation to a new one without losing the intended result. The Pragmatic Engineer's overview of software migration stages separates preparation, execution, post-migration work, and the long tail, which explains why completion extends beyond installing new code.
Reprocessing is therefore a compatibility operation, not proof that Home Assistant forgot the source data. The important questions are which stored representation changed, whether the work makes forward progress, and which functions remain available. Different releases may touch none, one, or several of these layers.
Schema Migrations Can Read and Rewrite Large Tables
A database schema defines tables, columns, types, indexes, and constraints. An upgrade may add a column, widen an identifier, rebuild an index, or transform rows into a new layout. Operations that look small in release notes can scan or copy a large Recorder database and create substantial temporary I/O.
An observed Home Assistant Recorder migration logged index removal and recreation on a multi-gigabyte database, including a warning that index creation could take several minutes on large databases or slower hardware.
The work scales with affected rows and storage behavior, not only CPU percentage. A migration can be I/O-bound, lock-bound, or limited by the database engine while processor use looks low. Interrupting it repeatedly may restart work or leave the system requiring validation, so progress and logs matter more than an arbitrary elapsed-time guess.
Derived Indexes and Caches Must Match the New Code
Indexes, caches, compiled assets, and lookup structures are derived from authoritative data. Reusing them after their format or invalidation rules change could return stale entities, incorrect queries, or mismatched frontend resources. Discarding and rebuilding them trades temporary work for a consistent result under the new version.
Cache consistency depends on removing entries whose source assumptions have changed. Meta's engineering account of cache invalidation and consistency explains that a cache is not the source of truth and can remain indefinitely inconsistent when invalidation is mishandled.
This mechanism explains why the first start or first dashboard load can be slower than later ones. Once compatible derived state exists, later access reuses it. If the same expensive rebuild repeats on every restart, investigate why the result is not being committed or recognized rather than accepting it as normal warming.
Integrations Reconcile Devices, Entities, and Sessions
Each integration must restore credentials, establish sessions, discover devices, map identifiers, and update entity availability. An upgrade may change setup logic, entity models, library versions, or migration handlers. Existing configuration is then reloaded through new code so the integration can produce state consistent with the current runtime.
Integration reload behavior makes this lifecycle visible. A community explanation of Home Assistant configuration-entry reloads identifies the reload action that unloads and sets up an integration again, the same broad reconciliation boundary exercised during startup.
A cloud API, sleeping battery device, or unavailable gateway can extend reconciliation independently of database work. Missing entities during early startup may be temporary, but repeated authentication failures or identifier churn are not evidence of healthy progress. Separate integration retries from Recorder migration logs before assigning the cause.
Statistics May Be Rebuilt From Retained History
Home Assistant keeps raw or short-lived state history alongside derived statistics used for longer-term views. When a calculation rule, metadata relation, or summary structure changes, retained rows may need to be reread to repair or regenerate the derived series. That creates additional reads and writes without changing the source device measurements.
The distinction between entity history and long-term statistics is operationally important. A detailed community guide to Home Assistant statistics recovery treats summarized statistics as a separate data layer that can be reconstructed or moved independently from ephemeral history.
A rebuilt summary should converge to stable values and normal write volume. Watch for gaps, duplicates, changing metadata identifiers, or a job that restarts from the same point. Those patterns suggest a compatibility or integrity problem rather than a finite pass over retained data.
Normal Progress Has a Different Shape From Failure
Expected post-upgrade work has a named task, increasing progress or changing log milestones, bounded resource use, and eventual completion. Failure repeats the same error, exhausts disk space, restarts the migration, leaves Recorder unavailable indefinitely, or produces new corruption warnings. Time alone cannot reliably separate them because databases and hardware differ.
A failed migration provides concrete counterevidence to the idea that waiting is always safe. In one Home Assistant database upgrade failure, the migration filled available VM storage and only proceeded after capacity was increased, showing that repeated failure can have a resource boundary rather than a patience boundary.
Do not delete a database merely because startup is slower than usual. Preserve the pre-upgrade backup, record the exact version pair, and observe free space, database activity, and logs. Escalate when the same error recurs, progress stops across multiple observation intervals, or required services exceed the planned outage window.
Use a Staged Post-Upgrade Observation Protocol
Before upgrading, record database size, free space, normal startup time, integration count, and a known-good backup identifier. After the new version starts, check migration messages, storage growth, Recorder availability, entity recovery, and statistics consistency at fixed intervals. Avoid overlapping backups or scans that would distort the first-start workload.
Migration experience is easier to interpret when recovery artifacts and version state are documented in advance. One operator's Home Assistant migration account illustrates how backups, restore behavior, and environment changes become part of the real transition rather than a final afterthought.
Declare success only when logs stop reporting migration work, Recorder accepts new events, history and statistics answer checks, integrations stabilize, and a second restart returns near the expected baseline. Keep the ZimaSpace recovery path for a known-good database backup available, but use it only after the observed failure crosses the recovery threshold.
