A multilingual family RAG index often fits in 16โ32GB RAM, but chunk count and index design matter more than language count alone.
A home archive with 500,000 chunks can use one multilingual embedding per chunk rather than one copy per language. Memory still grows through vector dimensions, graph links, metadata, caches, rerankers, and the generation model. The useful target is therefore a measured peak working set with headroom, not a โgigabytes per languageโ rule under peak load.
Start With Vectors, Then Add the Search Structure
Raw vector memory is chunk count multiplied by dimensions and bytes per value. At float32, 500,000 vectors with 768 dimensions contain about 1.54 GB of coordinates. Float16 halves that coordinate payload, although database support and accuracy behavior must be verified.
An overview of HNSW graph indexing explains why HNSW keeps a graph of neighbor connections for fast approximate search. Those connections, IDs, alignment, and allocator overhead sit above the raw vector calculation.
Metadata filters, document IDs, text caches, and duplicated build-time structures can exceed expectations. A disk-backed database may still keep hot graph pages in memory, while an in-memory engine may retain nearly the full index. Raw vectors are the floor, not the final RAM requirement.
Multilingual Coverage Changes Chunks More Than Arithmetic
A multilingual embedding model maps several languages into one vector space, so adding a language does not automatically duplicate every vector. RAM rises when translated copies are separately chunked, language-specific indexes are maintained, or tokenization produces more chunks for the same documents.
Research on multilingual embeddings evaluates shared representations across many languages, supporting one-index designs when the chosen model aligns those languages adequately. Coverage quality can vary by language even when memory does not.
The generator and reranker also compete for system memory. A 16 GB server may hold a moderate index but page heavily once an LLM, OCR process, and database cache run together. More RAM does not correct weak multilingual retrieval; it only prevents memory pressure from distorting the test.
Where the 16โ32GB Range Stops Applying
Sixteen gigabytes is plausible for hundreds of thousands of compact vectors with disk-backed text and a small local model. Thirty-two gigabytes is a safer starting point near one million 768-dimensional vectors plus services. Higher dimensions, multiple replicas, separate language indexes, or a resident larger LLM can justify 64 GB or more.
A capacity discussion on HNSW index memory shows that raw vector bytes can be only a fraction of total HNSW memory once graph structures are included. Implementation choices make any universal ratio unsafe.
These ranges fail when the database uses compression, memory mapping, product quantization, or a graph configured very differently. They also fail during index construction if the builder briefly holds old and new copies. Measure steady search and rebuild peaks separately.
Size RAM From a Measured Working Set
Calculate raw vectors first, then ingest ten percent of the intended corpus with final dimensions, metadata, and index parameters. Measure resident memory after warm search, concurrent queries, and one rebuild. Multiply only the components that scale linearly, then reserve at least 25 percent operating headroom.
Run the prototype beside the planned home vector database workload because model and database peaks may overlap. Keep swap activity and page-fault rate in the record.
Choose 16 GB only when the extrapolated peak remains below roughly 12 GB; choose 32 GB when it stays below roughly 24 GB. Move higher when rebuilds or concurrent inference cross that boundary. Recalculate after changing chunking or embedding dimensions.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
