Private AI for Family History: How OCR and Entity Linking Change Archive Exploration
OCR and entity linking change family-history research by turning document images into searchable clues and connecting repeated people, places, dates, and relationships.
A family archive may contain certificates, directories, newspaper clippings, letters, photographs, and handwritten notes whose filenames reveal almost nothing. OCR creates text that can be searched; entity linking proposes that “Juan Alvarez” and “José Alvarez” may refer to one person. Running both locally keeps private family material controlled while preserving a path back to each scan.
OCR Changes Scans From Containers Into Searchable Clues
A scanned page is initially a grid of pixels. OCR segments lines and characters, predicts text, and stores positions that can point a result back to a region on the image. That makes a surname, occupation, street, or witness searchable even when nobody previously catalogued it.
A practical genealogy account shows how digitized newspaper OCR can surface newspaper references that remained undiscovered through conventional searching. The gain comes from converting image content into candidate text, not from proving that every recognized character is correct.
Searchable text expands exploration because one query can cross many document types. Yet the image remains the evidence: OCR is a derived layer whose mistakes should be visible, correctable, and linked to the exact page or crop that produced them.
Entity Linking Builds Paths Across Separate Records
Entity linking normalizes mentions and scores whether they refer to the same person, place, organization, or event. A birth record, census line, obituary, and letter may use different spellings, but shared dates, relatives, addresses, and occupations create a network of corroborating features.
Research on genealogy research practices reports how genealogists organize evidence, collaborate, and struggle with unsupported online-tree connections. Linking works best when it treats names as one signal among many rather than copying a convenient identity across every record.
The result is a navigable graph: selecting a person can reveal related documents, places, and uncertain aliases. Exploration becomes faster because the system proposes paths, while the researcher retains responsibility for accepting, rejecting, or splitting each identity.
Where Historical Text and Identity Resolution Break
Old typefaces, bleed-through, damaged pages, abbreviations, changing borders, reused names, and inconsistent ages all create ambiguity. OCR errors can corrupt a key surname; entity linking can then amplify that error by attaching several unrelated records to one profile. More links do not automatically mean better evidence.
An OCR-and-linkage study of historical record linkage found materially different accuracy between extraction and final record linkage, illustrating that pipeline stages fail independently. A strong match score can still inherit a bad transcription or an incomplete reference database.
The claim stops applying when the archive lacks distinguishing attributes or when the model hides alternatives. In that boundary, keep multiple candidates, show the contributing fields, and avoid converting a probabilistic match into a family-tree fact.
Verify One Proposed Family Connection
Select one candidate connection and create a small evidence packet: the original images, OCR text, normalized names, dates, locations, relationships, and the model’s match score. Mark which fields agree, conflict, or are missing, and distinguish information copied from another tree from information visible in a record.
Use the provenance discipline described for family-archive lineage: every claim should retain its document, version, and transformation path. Recheck decisive text against the scan and search for at least one independent record that was not used to create the initial match.
Accept the connection only when the identity is supported by several compatible attributes and no unresolved contradiction changes the conclusion. Otherwise label it as a research lead. That preserves exploration speed without allowing an OCR guess to become inherited certainty.
