OCR text differs because camera photos introduce variable geometry and illumination, while flatbed scans usually present flatter, more uniform character shapes.
A receipt photographed above a desk can be sharp in the center yet skewed, shadowed, or curved near an edge. A flatbed keeps the page at a fixed distance and lights it along a controlled path. OCR therefore receives two different image distributions even when the printed page is identical and recognizer settings under one controlled comparison.
Capture Geometry Changes the Character Shapes
A camera projects a three-dimensional scene onto a sensor. Tilt creates keystone distortion, page curl bends text lines, and lens distortion changes scale across the frame. OCR segmentation must first infer where characters and lines are before recognizing them.
A survey of camera-captured documents identifies blur, low resolution, perspective distortion, and complex layout as characteristic challenges. Flatbed capture removes or stabilizes several of those variables.
Rectification can make a photographed page look rectangular, but interpolation resamples strokes. Thin punctuation may vanish and adjacent letters may merge. Geometry correction improves layout while sometimes changing the pixels the recognizer uses for individual glyphs.
Lighting and Focus Alter the Stroke Evidence
Flatbeds provide consistent illumination close to the paper. Camera photos inherit shadows, glare, white-balance shifts, depth of field, motion blur, and sensor noise. Adaptive thresholding may treat a shadow as background in one area and erase faint print in another.
An experimental study on mobile document capture examines how users position and orient phones for document images, illustrating that acquisition itself is part of OCR quality.
Compression adds another difference. Phone pipelines may sharpen edges, denoise texture, and encode JPEG blocks before OCR sees the image. Those enhancements can help large text but corrupt small characters, especially decimal points, serial numbers, and low-contrast marks.
Where the Capture Device Is Not the Cause
Capture differences do not explain errors that repeat at the same words in a clean crop and a high-resolution scan. Unusual fonts, languages, handwriting, or document layout can exceed the recognizer’s training regardless of camera geometry.
Research on document image quality separates image quality from recognition capability by testing controlled degradations. Such controls are necessary before attributing every token difference to the device.
The mechanism also stops applying when each input takes a different downstream path, such as cloud OCR for photos and local OCR for scans. Different orientation detection, language settings, or post-correction dictionaries can change text after capture. Match the software path before judging hardware.
Compare Capture Variables With One OCR Pipeline
Capture the same page with a flatbed and camera, then create camera variants for tilt, shadow, motion, and distance. Feed original images and normalized crops through the same OCR engine, language pack, resolution, and post-processing. Compare character errors by region and symbol class.
Store the paired images and transcripts in a local-first OCR workflow so preprocessing versions remain traceable without uploading sensitive pages. Preserve raw camera files before automatic enhancement.
If rectification closes the gap, geometry dominated. If errors follow dark or glossy regions, lighting dominated. If scan and normalized photo still miss identical terms, investigate model coverage or document layout. Judge numbers and punctuation separately because a similar word-error rate can hide higher practical risk.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
