Wide-angle tracking often feels unstable because distorted edge geometry and small subjects make frame-to-frame position and appearance less consistent.
A person crossing a wide driveway may move smoothly in the real world but accelerate across the image edge, stretch, and shrink toward the center. A home NVR tracker links detections in pixel coordinates, not in physical space. When geometry and object detail change together, the association step has less stable evidence.
Wide Lenses Turn Constant Motion Into Nonlinear Image Motion
A wide field of view maps more scene angle into the same sensor width. Near the edge, radial distortion bends lines and changes apparent object shape; perspective also makes nearby subjects grow rapidly. A tracker that assumes similar displacement and appearance between frames can underestimate those changes.
An engineering discussion of wide-angle distortion shows how straight-line geometry can be used to estimate and correct wide-angle distortion. The need for that correction reveals why raw edge coordinates do not behave like a simple pinhole image.
The track may jump to a nearby detection, lag behind the subject, or receive a new identity at the edge. Increasing detector sensitivity does not necessarily fix association geometry. More detections can even create more candidates for the tracker to confuse.
Edge Subjects Carry Fewer Useful Pixels
Wide coverage makes each distant person or vehicle occupy fewer pixels. At the edge, blur, shading, and resampling after lens correction can further reduce distinctive texture. The detector may still find a box, while the tracker lacks the stable appearance features needed to connect that box to the previous frame.
The TartanCalib project project reports that accurate wide-angle calibration improves feature detection and downstream geometric tasks. Its results illustrate that calibration quality changes the usable features available near extreme image regions.
This produces a characteristic pattern: stable identity near the center, more jitter or fragmentation near the outer quarter, and recovery after the subject returns inward. If instability is uniform across the frame, resolution, shutter speed, or tracker settings are more likely than lens geometry alone.
Where Wide Angle Is Not the Root Cause
A wide lens can track well when the model is trained for fisheye views, the image is correctly undistorted, and subjects remain large enough. Conversely, a normal lens can track poorly under motion blur, occlusion, low frame rate, or crowded scenes. Field of view is a risk factor, not a verdict.
An optics overview explains how wide-angle lens distortion alters straight lines and edge shape. It also distinguishes optical distortion from perspective, which cannot be removed simply by applying a barrel-distortion profile.
The mechanism fails when track breaks align with occlusions or dropped frames rather than edge position. It also fails if the NVR detects from an already-corrected stream but overlays boxes on the raw stream; then the apparent jump can be a coordinate-transform mismatch rather than actual tracking failure.
Map Track Stability Across the Camera Field
Plot track-center coordinates for the same walking path through the left edge, center, and right edge. Keep frame rate, shutter, model, and subject distance as constant as practical. Compare raw and correctly undistorted inference while recording box size, confidence, identity changes, and dropped frames.
Use a dedicated local AI mini PC to ensure the same compute load and video source feed both trials. This prevents simultaneous media workloads from masquerading as a lens effect through skipped inference frames.
Wide-angle geometry is causal when edge regions show larger residual motion or more identity breaks after controlling for object size and dropped frames. If correction improves overlays but not associations, the tracker needs distortion-aware motion or appearance handling. If failures follow load spikes, investigate inference cadence instead.
Private Search Score Calibration: How Raw Similarity Becomes a Usable Confidence Signal
Learn why cosine similarity is not confidence, how labeled queries calibrate scores, and how to monitor thresholds when a private corpus changes.
Local AI NUMA Locality: Why Memory Placement Changes Accelerator Feed Rate
Learn how CPU, RAM, and PCIe topology affect accelerator feeding, why automatic placement can vary, and how to benchmark NUMA binding safely.
Model File Memory Mapping: How Shared Pages Reduce Duplicate RAM Use
Understand how mapped model pages are faulted and shared, why RSS can mislead, and which caches and buffers still consume RAM per process.
