Motion sensors often feel more sensitive in hallways because people cross dense detection zones at close range instead of moving radially or distantly.
A hallway light can trigger with one step while the same sensor misses someone entering a wide living room. The sensor has not gained sensitivity; the path and thermal geometry changed. Narrow circulation routes repeatedly carry warm bodies across the lens pattern where PIR detection is strongest.
PIR Responds to Change Across Zones, Not to Presence Itself
A Fresnel lens divides the field into alternating detection regions. When a person crosses those regions, the sensed infrared pattern changes quickly. Walking straight toward the sensor can remain within one region longer, producing a weaker differential signal even at the same distance.
PIR placement guidance recommends making a person intersect coverage zones rather than approach directly. Hallways naturally create that repeated crossing pattern when the sensor looks across the corridor.
This geometry makes response feel crisp and repeatable. In an open room, people may approach from many directions, move behind furniture, or sit within one zone. The device appears less sensitive although its electronic threshold has not changed.
Distance and Background Temperature Change the Signal Margin
A narrow hallway keeps occupants relatively close and often presents a simple background. Open rooms allow longer ranges and warm windows, floors, fireplaces, or sunlight patches that reduce contrast between a person and surroundings. Smaller angular motion also crosses fewer lens regions per second.
Consumer safety guidance likewise notes that motion sensors perform best when movement is parallel to the sensor, not directly toward the device. Layout determines how often real paths satisfy that condition.
More electronic sensitivity can recover weak motion but also amplify pets, curtains, HVAC drafts near warm surfaces, or sunlight changes. A hallwayโs strong geometry can tolerate a conservative threshold, while an open room exposes the false-trigger tradeoff.
Where Hallway Geometry Is Not the Explanation
The hallway mechanism fails if the two rooms use different sensor models, mounting heights, battery states, cooldowns, or automation delays. Microwave and mmWave sensors do not share PIRโs exact thermal-zone behavior. Doors and wall materials may also constrain radar in ways that make a corridor less reliable.
Community explanations of cross-field motion distinguish cross-field motion from movement toward or away from a PIR. That principle is useful only after confirming the device actually uses PIR as the trigger.
The claim also stops applying when open-room failures occur at close cross angles, which points to obstruction, lens contamination, or state logic. โMore sensitiveโ should mean a lower detection threshold under matched conditions, not simply a faster automation in one room.
Test Direction and Distance With the Same Sensor
Mount the same sensor temporarily at equal height and settings, then walk matched paths across and toward it at two, four, and six meters. Record raw detection time, angle, room temperature, cooldown state, and hub receipt. Do not compare only the light response.
Store trials in a local event history log so direction and raw event timing can be reviewed rather than remembered. Keep automations identical across the two locations.
If cross-path trials stay fast in both rooms while radial trials lag, zone geometry explains the hallway advantage. If all open-room paths lag, inspect distance and thermal background. If raw detections match but lights differ, the sensitivity difference exists in automation or device response, not the sensor.
How to Measure Local RAG Retrieval Quality and Interpret Recall, Precision, and Citation Coverage
Build a local RAG test set, calculate core retrieval metrics, interpret their tradeoffs, and audit whether answer claims are supported by cited evidence.
Why Does Smart Home Feature Computation Matter More as Sensor Count Increases at the Same Sampling Rate?
Trace per-sensor and cross-sensor compute as device count rises, identify nonlinear fusion costs, and benchmark the feature pipeline before automations lag.
Why Does RAG Evaluation Cost Matter More as the Document Library Grows at the Same Query Volume?
Understand why corpus growth raises RAG evaluation effort without more user queries and how stratified tests keep cost tied to risk.
