A circuit breaker keeps one failing home AI tool from stalling every request by stopping repeated calls until recovery becomes plausible.
An agent may depend on search, transcription, a camera API, and a smart-home bridge. If one tool hangs, every workflow that touches it can consume a worker, wait for a timeout, and retry. A circuit breaker converts repeated failures into a temporary fast rejection, preserving threads and queue capacity for requests that can still succeed.
Repeated Timeouts Consume Capacity Beyond the Broken Tool
A timeout occupies a connection, worker, and workflow deadline while producing no useful result. Parallel agent steps can multiply that cost, and retries can keep an already unhealthy dependency busy. The local model may be fast while users wait on the same doomed external call.
AWS describes the circuit breaker pattern as a stateful proxy that monitors failures and blocks requests once a threshold is reached. The pattern differs from a retry because it stops spending capacity on a dependency expected to fail.
Fast failure allows the orchestrator to omit an optional step, use cached evidence, or report partial availability. It also keeps the root queue from filling with calls that cannot complete before their deadlines. This distinction remains important under realistic household operating conditions.
Closed, Open, and Half-Open States Control Recovery
In the closed state, calls flow and failures are counted. Crossing the configured threshold opens the circuit and rejects calls for a cooldown. The half-open state then admits a limited probe; success closes the circuit, while failure reopens it.
Microsoft guidance on breaker states emphasizes that failure counts, timeout, and recovery behavior must fit the operation. One shared breaker can be too coarse when read and write endpoints have different failure modes. The intermediate state should remain visible during later diagnosis and review.
The breaker should be scoped to the tool operation and failure class. Authentication errors, rate limits, timeouts, invalid arguments, and model refusals need different recovery rules; combining them under one counter can hide the real fault.
Fallbacks Can Preserve Availability While Reducing Correctness
A cached weather value may be adequate for display but unsafe for closing windows during a storm. A CPU model may answer slowly but correctly, while a generic result can look complete and mislead the agent. Circuit breakers protect capacity, not semantic quality.
The agent circuit breakers catalog applies circuit breaking to agent tools and notes the need for fallbacks and observability. In an agent, the open-circuit result must remain structured so the planner can distinguish unavailable evidence from a negative answer.
The failure boundary is any action that requires the missing toolโs current result. In that case, fail closed, disclose the unavailable dependency, and request approval or retry later rather than silently substituting stale or weaker evidence.
Inject One Tool Failure and Trace Isolation
Choose one non-destructive tool and inject timeouts, errors, and slow responses while mixed workflows continue. Record breaker state, failure window, concurrent calls, queue depth, fallback selected, and recovery probes. Verify that unrelated tools retain their normal latency.
Test the CPU fallback boundary described in CPU failover, but label degraded execution explicitly and measure whether it still meets the workflow deadline. Confirm that a half-open probe cannot trigger a burst of waiting requests.
Pass only if the failing operation is isolated, callers receive a structured unavailable state, and recovery closes the breaker after controlled probes. If cached or fallback results change an action, add a policy gate before enabling that fallback.
Private Search Score Calibration: How Raw Similarity Becomes a Usable Confidence Signal
Learn why cosine similarity is not confidence, how labeled queries calibrate scores, and how to monitor thresholds when a private corpus changes.
Local AI NUMA Locality: Why Memory Placement Changes Accelerator Feed Rate
Learn how CPU, RAM, and PCIe topology affect accelerator feeding, why automatic placement can vary, and how to benchmark NUMA binding safely.
Model File Memory Mapping: How Shared Pages Reduce Duplicate RAM Use
Understand how mapped model pages are faulted and shared, why RSS can mislead, and which caches and buffers still consume RAM per process.
