GPU-to-CPU failover works only when the service plans a compatible secondary execution path before memory exhaustion interrupts an active request.
A home AI server may run transcription, image search, and an LLM on one accelerator until a long prompt pushes memory beyond its safe limit. Simply catching an out-of-memory error is too late if model state is inconsistent. Reliable failover combines admission control, compatible CPU weights, transferable request state, bounded queues, health signals, and a clear degraded-service policy.
Admission Control Detects Pressure Before Allocation Fails
The gateway estimates model weights, KV cache growth, temporary tensors, batch size, and memory fragmentation before accepting a GPU request. Reserved headroom protects kernels and concurrent workloads, while a pressure threshold decides whether to delay, shrink, offload, or route the request.
paged KV memory treats GPU memory as paged blocks so serving can reduce fragmentation and share KV-cache capacity more efficiently. This raises the safe operating ceiling, but it does not create unlimited memory or replace an explicit overflow route.
A real failover decision uses both predicted and observed consumption. Free-memory readings alone can be misleading because cached allocators, pending kernels, and another serviceโs reservation may consume space after the check but before the next allocation.
The CPU Path Must Reconstruct Compatible Model State
CPU execution needs the same tokenizer, model revision, quantization semantics, prompt template, sampling settings, and stop rules as the GPU path. The service may keep a warm CPU replica, memory-map weights, or load them on demand according to its recovery-time budget.
hybrid CPU-GPU inference demonstrates hybrid inference that exploits predictable activation sparsity across CPU and GPU on consumer hardware. Its design shows that CPU participation can be planned as an execution mode rather than treated only as an emergency copy.
Requests that have already generated tokens are harder to move because their KV cache and random state must be transferred or recomputed. Many home services should therefore fail over at request boundaries and retry idempotently instead of promising seamless mid-token migration.
Health, Queues, and Degraded Mode Bound the Consequences
A circuit breaker marks the GPU unavailable after repeated allocation faults, driver resets, or health-check failures. New work enters a separate CPU queue with lower concurrency, shorter context limits, or a smaller fallback model so slow requests do not collapse the host.
tiered inference placement coordinates CPU, GPU, and storage placement to run models beyond accelerator memory. The results illustrate the large latency difference between fitting in fast memory and relying on slower tiers. This distinction remains visible during later household testing.
The failure boundary is pretending CPU failover preserves the same service level. A model that takes 20 seconds on GPU may take minutes on CPU, and unsupported kernels may not run at all. The interface should expose fallback model, limits, estimated delay, and cancellation rather than silently stalling.
Prove Failover Under Controlled Memory Pressure
Replay short prompts, long prompts, concurrent requests, and another GPU workload while gradually reducing available memory. Trigger pre-admission routing, an allocation failure before generation, a driver reset, and cancellation during the CPU queue. The intermediate result must remain inspectable before automation follows.
Compare the results with the fallback boundary in GPU memory fallback. Record success rate, duplicated side effects, token equivalence where expected, p95 latency, queue age, host RAM, recovery time, and whether the user saw degraded-mode status.
Pass only when no accepted request disappears and CPU routing cannot exhaust system memory. If mid-request migration changes output or repeats a tool action, restrict failover to safe checkpoints and return a resumable error for everything else.
What Features Enable a Home AI Trust Boundary Around Sensitive Files?
See how classification, capability-scoped access, isolated parsing, retrieval filters, egress policy, approvals, and audits contain sensitive home files.
What Factors Determine Whether Merkle-Tree Backups Detect Silent Change Efficiently?
Learn how chunk size, fan-out, trusted roots, cached hashes, change locality, metadata scope, and scrubbing determine Merkle backup verification cost.
What Components Enable Verifiable Backups of AI Indexes and Model State?
See how coordinated snapshots, content manifests, checksums, version locks, restore drills, and query tests prove that AI state can actually recover.
