Agent memory stores the right household facts only when it selects durable information, links it to evidence, resolves entities, and updates conflicts under explicit rules.
โThe guest-room lamp is called Moonโ may be a durable preference, while โturn it off tonightโ is a temporary instruction and โthe thermostat is brokenโ may be an unverified observation. A memory system must decide what deserves persistence, who the fact belongs to, how confident it is, when it expires, and whether later evidence corrects or merely adds context.
Memory Admission Separates Durable Facts From Passing Context
The extractor proposes atomic facts with subject, predicate, value, owner, scope, timestamp, and source span. Admission rules reject commands, guesses, sensitive details without consent, and facts already represented at equal or better quality. The model proposes; policy decides what becomes durable.
A survey of agent memory architectures describes memory systems as architectures that combine storage, retrieval, and control rather than simple conversation archives. The distinction matters because saving more text can increase inconsistency and retrieval noise.
Household entities need canonical identities. โMom,โ โSophia,โ and an account ID may refer to one person in one context but not another, while โoffice lightโ may name a group or a device. Ambiguous mappings should remain unresolved instead of silently overwriting an existing fact.
Provenance and Conflict Rules Control Updates
Every stored fact should point to the user statement, device observation, document, or approved tool result that supports it. New evidence is compared with active facts by entity, attribute, time, and authority before the system appends, supersedes, or flags a conflict.
Research on memory provenance shows that memory provenance must track contradiction, invalidation, and contamination because stored records can later steer agent behavior. Provenance makes a conflict inspectable; it does not automatically decide which source wins.
Explicit user corrections usually outrank inferred repetition, but sensor facts may require freshness windows and device reliability. Preserve the previous value and the supersession edge so the agent can answer both โwhat is true now?โ and โwhat did we believe last week?โ
Retrieval Determines Which Stored Fact Reaches the Agent
A correct fact is useless if retrieval misses it or mixes it with a stale contradiction. Memory search combines entity filters, recency, relevance, salience, and access scope, then presents compact evidence with status and provenance rather than an undifferentiated transcript.
The adaptive memory organization framework addresses rigid retrieval granularity and accumulation-heavy maintenance with adaptive memory organization. Its reported gains show why memory quality includes what is retrieved and compressed, not merely what was written. This distinction remains visible during later household testing.
The failure boundary is uncontrolled consolidation. Summaries can erase qualifiers, merge two people, or let repeated old facts defeat one recent correction. Sensitive or consequential facts should remain user-editable, versioned, and traceable to their original evidence.
Run a Memory Correction and Conflict Suite
Create cases for a durable preference, temporary request, nickname collision, shared-device fact, user correction, contradictory sensor reading, expired schedule, malicious document statement, and deletion request. Define the expected memory operation before running the agent. The intermediate result must remain inspectable before automation follows.
Compare the outcomes with memory conflict behavior, which explains how repeated older facts can overpower recent corrections. Inspect admission decisions, canonical entity IDs, provenance, confidence, expiry, supersession edges, retrieved context, and the final answer. That boundary should be measured separately under realistic operating conditions.
Pass only when durable facts survive new sessions, temporary context expires, corrections become active without erasing history, and unauthorized memories never cross users. If a reviewer cannot edit or delete a fact directly, the memory is not adequately controlled.
What Components Enable Hybrid Search Across NAS Files?
Learn how exact identifiers and semantic meaning reach one ranked NAS search result without bypassing permissions or hiding weak evidence.
What Features Enable Reliable Document Version Selection in RAG?
See how RAG selects the applicable revision instead of the most similar stale copy, and how to test explicit, implicit, and overlapping updates.
What Factors Cause Agent Plans to Diverge From Available Tool Permissions?
Learn how discovery, delegation, policy feedback, and replanning keep an AI agentโs proposed steps aligned with what its tools may actually do.
