What Components Enable Event Summaries Without Storing Every Camera Frame?
Event summaries can survive without continuous video when edge processing converts transient frames into selected evidence, temporal metadata, and traceable event records.
A camera produces thousands of near-duplicate frames during an uneventful hour, yet a useful NVR may need only to remember that a package arrived at 14:03. A rolling buffer keeps short-lived context while detectors open and close event windows. The system then retains representative frames, object tracks, captions, timestamps, and confidence, deleting raw frames after the configured verification window.
A Rolling Buffer Separates Capture From Retention
Each stream first enters a bounded circular buffer holding several seconds or minutes of encoded video. Motion, object, audio, or zone rules trigger an event and copy only the relevant pre-roll and post-roll context into a temporary workspace.
A survey of edge video analytics describes how cameras and nearby devices detect spatial and temporal events under accuracy, latency, energy, and resource constraints. The architecture supports filtering near the source before footage becomes long-term storage.
Event windows need hysteresis so one visitor does not become dozens of records when detection flickers. Track continuity, quiet-time thresholds, and maximum duration join nearby signals while preventing an endless event from consuming the entire rolling buffer.
Keyframes and Structured Features Preserve Compact Evidence
A selector can retain the first clear view, the highest-quality object crop, a representative action frame, and the final state. Alongside them, the NVR stores object classes, track IDs, zones, timestamps, motion direction, confidence, and optional audio markers.
thumbnail-based summarization uses thumbnail containers and hierarchical analysis to summarize long video on constrained edge devices. Its approach demonstrates how representative visual units can reduce processing while preserving salient content. This distinction remains visible during later household testing.
Embeddings make events searchable by visual similarity, while captions make them searchable with language. Neither is a substitute for provenance: every feature and sentence must point to the event window, camera, selected frame, model version, and retention decision that created it.
Temporal Reasoning Builds Summaries From Event State
A useful summary combines ordered changes: a car entered, stopped, a person approached, and the package remained after departure. This requires track and zone state across time rather than captions generated from unrelated sampled frames.
condensed video memory condenses streaming video into visual features and semantic captions, then integrates them into global context and an entity graph. The separation shows how long-range memory can be smaller than the original pixel stream.
The failure boundary is later forensic detail. Discarded frames cannot reveal a license plate missed by the selector or disprove a mistaken caption. High-risk zones may therefore retain encrypted clips longer, while low-risk areas keep only structured events and reviewed keyframes.
Measure Summary Utility Before Shortening Retention
Collect a week of consented test events and keep the full clips temporarily as ground truth. Generate compact records using several keyframe counts, event-gap thresholds, caption models, and raw-buffer windows, then ask realistic review questions without exposing the reference clips.
Compare event understanding with the frame-to-event transition in event-level NVR memory. Score event recall, temporal-order accuracy, entity consistency, keyframe sufficiency, false summaries, bytes per event, and the percentage of questions that require reopening raw video.
Shorten retention only when compact records answer the declared use cases and uncertainty is visible. If a safety or dispute workflow routinely needs discarded detail, retain bounded encrypted clips for that class rather than pretending summaries are reversible.
