An approval queue separates AI suggestions from home-server actions by storing a proposed tool call in a pending state until an independent decision releases it.
This turns high-impact automation into a two-stage system: the agent can prepare an exact action, but files, services, accounts, and devices remain unchanged until approval and revalidation.
The Agent First Produces a Proposal, Not a Side Effect
An approval queue changes the output of a high-impact decision from execute now to create a pending action.
The model can still populate parameters, but the external system is not changed yet.
Temporal's approval pattern describes workflow execution blocking until an external approval decision arrives. The wait is part of workflow state. LangChain human-in-the-loop middleware can interrupt a tool call before execution, demonstrating the proposal-first boundary described in LangChain human-in-the-loop middleware.
A delete, permission change, container restart, or bulk move can therefore become reviewable data while the target remains unchanged.
A Pending Record Freezes the Action Under Review
The queue should preserve the tool name, target, arguments, requester, reason, and creation time. Freezing those fields prevents approval from becoming a blanket permission.
Temporal's human-in-the-loop examples use signal-based approval and durable waiting, illustrating how a workflow can retain state while waiting. Temporal models approval as a workflow waiting state, which supports keeping a pending action record separate from the eventual side effect in Temporal approval pattern.
If the proposal says restart Jellyfin, that approval should not authorize a later mutation to restart PostgreSQL.
Material parameter changes should invalidate the old decision.
The Reviewer Chooses Approve, Edit, Reject, or Expire
Approval need not be binary. A reviewer can reject the action, approve it unchanged, modify a constrained parameter, or let it expire when the context is stale.
Temporal captures approval data through workflow signals. That makes reviewer metadata part of the durable workflow state. AWS Step Functions provides human-approval workflows that pause before continuing, illustrating the approve-or-reject transition described in AWS Step Functions human approval.
Editing must remain bounded. If the review UI accepts an arbitrary replacement shell command, it becomes a second unrestricted tool surface rather than a decision gate.
Execution Revalidates Instead of Trusting Old Context
Approval may arrive long after the proposal. During that time, a file can move, a service can recover, or permissions can change.
Durable workflows can remain blocked until a decision is received. The executor should then rerun schema checks, authorization, and preconditions against the approved parameters. Camunda exposes agentic work inside explicit workflow structures, reinforcing the need to revalidate state before a previously proposed action is released in Camunda agentic workflow controls.
This prevents approval from freezing stale assumptions. A delete can be rejected if the target now points to a different version, and a restart can be skipped if the service is already healthy.
Approval Adds a Boundary Above Schema and Permission
Schema validation asks whether an action is structurally valid. Authorization asks whether the caller may perform it.
Approval asks whether this specific valid, authorized side effect should be released now.
ZimaSpace's read-only home AI agent strategy recommends observation before modification. MCP tool guidance treats tool invocation and user-visible control as distinct concerns, supporting the layered relationship between schema, permission, and approval in MCP tool safety guidance.
The same boundary appears in ZimaSpace's self-hosted agent approval-gate examples, where gated tools pause for review rather than applying changes automatically.
The Queue Only Helps If Bypass Paths Are Closed
An approval system fails if the same agent can call an equivalent unrestricted endpoint directly. High-impact paths must share the same enforcement boundary or be denied separately.
MCP recommends explicit user confirmation for sensitive operations. An approval queue makes that confirmation durable and auditable. Microsoft Agent Framework can mark function tools as requiring approval before execution, which shows why an approval layer only works when execution paths cannot bypass it; see Microsoft Agent Framework tool approvals.
Low-risk reads may still execute automatically. The goal is not maximum friction; it is an enforceable transition between suggestion and side effect.
