Recent corrections can lose when memory ranking treats repeated older facts as stronger evidence and lacks an explicit supersession relationship between conflicting records.
A household agent may hear โthe guest Wi-Fi password changedโ once after storing the old password in several summaries, chats, and notes. A later query retrieves whichever memories score highest, not necessarily the newest truth. Without version, provenance, and conflict logic, repetition can outweigh recency and make the correction look like a weak exception today.
Repeated Memories Accumulate Retrieval Advantage
Memory systems often store observations, summaries, and extracted facts as separate items. Repeating one fact creates several semantically similar vectors, so a query can return multiple copies. Their apparent agreement is duplication, but a downstream model may interpret it as corroboration.
A practical overview of memory freshness distinguishes conversation state, retrieval, freshness, provenance, and deletion as separate design problems. Treating memory as one undifferentiated similarity index hides the relationships needed to resolve contradictory facts. That distinction changes the resulting household decision.
The result is a frequency bias: five stale memories occupy the context while one correction falls below the cutoff. Increasing top-k may expose the conflict, but it does not tell the agent which record should govern.
A Correction Needs Supersession, Not Just a New Timestamp
A robust store represents that fact B replaces fact A for a defined subject, predicate, scope, and effective time. The old record can remain for history, but current retrieval filters or downweights it. Provenance records who corrected it and from which authoritative event.
Research on implicit memory conflicts identifies implicit conflicts in which a new observation invalidates an old memory without using explicit negation. โWe moved to Denverโ changes the current home location even though it never says โwe no longer live in Austin.โ
Recency alone is insufficient because some old facts remain valid and some new statements are temporary or mistaken. Supersession combines time with semantic relation, authority, and scope, allowing the system to retain history without presenting it as current truth.
Where Automatic Conflict Resolution Becomes Dangerous
A model can misidentify two distinct facts as contradictory, such as a work address and home address, or a temporary schedule and standing preference. Automatically deleting the older item can destroy useful context and make later correction harder to audit.
An overview of memory consolidation separates short-term and long-term layers and emphasizes controlled movement between them. Promotion, consolidation, and forgetting policies determine what persists; they are not neutral storage operations. This boundary remains visible during later evidence review.
The mechanism fails when identity, scope, or authority is ambiguous. In that boundary, preserve both records, surface the conflict, and ask for clarification. A user-editable memory store should allow correction, merge, split, and deletion without relying on another model inference.
Run a Memory Supersession Test
Create one fact, repeat it in three differently worded interactions, then provide a clear correction with an effective date. Query directly, by paraphrase, and through a task that depends on the fact. Record retrieved memory IDs, scores, timestamps, and the final action.
Make the memory user-editable as recommended in user-editable memory, and verify that changing the canonical fact updates downstream retrieval without erasing the audit trail. Then add a temporary exception to test whether scope is preserved.
Pass only if current queries use the correction, historical questions can still recover the old state, and ambiguous exceptions trigger clarification rather than silent overwriting. Repeat after memory summarization or compaction, because those stages can recreate stale facts.
Multilingual Embeddings: How One Vector Space Connects Household Documents Across Languages
See how aligned embeddings connect documents across languages, why retrieval quality varies, and how to test cross-language evidence coverage locally.
Private Search Reranking: How a Second Model Changes the Final Evidence Order
See why first-stage similarity and second-stage relevance disagree, when reranking helps private RAG, and how to evaluate reordered evidence.
Local LLM Sampling: Why Decoding Settings Change Repetition and Stability
Learn how temperature, top-p, min-p, seeds, and penalties interactโand how to test decoding settings without confusing randomness with quality.
