Why Does Home Assistant Increase Fan Noise During Whole-Home Device Control?
Fan noise that rises only during whole-home control usually follows a short CPU or storage burst, but it can also expose a heavy dashboard, overlapping background job, restricted airflow, or a version-specific fault.
Reproduce one representative sceneโ€”such as changing many lights, blinds, thermostats, and media statesโ€”while watching host CPU, disk activity, temperature, Home Assistant response time, and other containers. Change one variable at a time, let the server return to baseline between tests, and stop if it becomes unresponsive, thermally throttles, shuts down, or produces mechanical fan noise.
Confirm That the Noise Follows the Control Event
Record the fan and temperature baseline after the system has been quiet for several minutes. Then run the same whole-home scene once and mark its start and end. Compare the timing of the noise with CPU, load average, disk writes, and container activity rather than judging by sound alone.
If the fan rises within seconds and settles soon after device acknowledgements finish, the pattern is consistent with a transient compute or event burst. If it starts later and continues, look for Recorder work, retries, camera streams, backups, indexing, or another container that overlaps the scene.
Repeat the test once after the host returns to baseline. A consistent signature gives you a controlled diagnostic path. An inconsistent signature means the trigger is incomplete; capture what else was running before changing automation logic or cooling.
Separate Automation CPU From Dashboard and Integration Load
Run the scene with nonessential dashboards and camera views closed. If CPU and fan response fall sharply, the visible control action may only be the moment when a live dashboard redraws many entities or streams. Keep the control logic unchanged so the comparison isolates the client load.
Community troubleshooting provides a useful bounded example: users traced sustained high CPU and temperature to always-on dashboards with live camera feeds, and lowering or closing those feeds restored normal load. The dashboard and camera test supports checking clients before blaming the automation engine.
If closing clients changes nothing, disable only one nonessential custom integration or automation group at a time and repeat the same scene. A lower peak identifies a candidate; no change moves the diagnosis toward Recorder, shared storage, another container, or host cooling.
Check Whether Recorder or Shared Storage Extends the Heat
Compare the scene timestamp with disk write rate and database latency. A large state fan-out can create many Recorder writes even after devices respond. If fan noise tracks disk activity longer than CPU activity, storage or database work is the stronger branch.
Temporarily reduce only nonessential high-frequency recording or move an overlapping backup outside the test window, then run the same scene. If device control stays the same but disk activity and fan duration drop, keep the change narrow and review which entities or jobs created the write burst.
The ZimaSpace explanation of storage latency during whole-home control provides the next diagnostic layer when writes, database waits, and shared-host contention appear at the same time.
Rule Out Cooling Limits and Version-Specific Faults
Inspect vents, dust, fan clearance, ambient temperature, and the host's fan curve with power removed before physical cleaning. Smooth airflow that follows temperature is different from rattling, grinding, sharp pitch changes, or a fan that stays at maximum after load and temperature fall.
If the behavior began immediately after an OS or Core update, compare the exact version and platform before generalizing. One HAOS 18.0 OVA report described 100% CPU and an unusable VM and was closed as a duplicate while still labeled as needing more information. That version-bounded HAOS case justifies checking release scope, not assuming every fan spike is the same regression.
Roll back only when you have a known-good image or backup and the trigger aligns with the update. Otherwise, preserve logs and system information and continue isolating workload. Escalate hardware inspection if noise is mechanical, temperatures remain unsafe at low load, or the host shuts down.
Verify the Fix With the Original Whole-Home Scene
Restore the normal client set and rerun the exact scene after applying the matched change. Watch the same CPU, disk, temperature, latency, and fan measures. A quieter idle state proves nothing if the triggering event is absent.
A successful result means device actions complete normally, CPU and storage return to baseline, temperature falls as expected, and fan noise settles without new retries or unavailable entities. Repeat after one restart and during the next scheduled background window.
If the fan remains loud but load and temperature are normal, stop changing Home Assistant and inspect the fan, bearings, mounting, or acoustics. If load remains high, preserve the controlled test results and escalate to the responsible integration, database, host, or OS project with the version and trigger clearly recorded.
